The Elite LX is the newest factory painted cover from UnderCover. The LX comes standard with all the features from the UnderCover Elite. Starting with a completely new design adding the handle to the back with a BOLT Lock making it codable to your trucks factory ignition key. The Elite LX cover includes Lanyard handy tool that allows you to easily access cargo that is just out of reach and when not in use it stores neatly out of the way. It also has a new brighter and removable LED light. They’ve added a premium carpet lined underside topped with a flawless paint match to make the LX the sharpest tonneau on the market. Engineered to provide a precise fit and finish to your truck bed. They have made America’s most popular tonneau cover even better.
This tonneau cover is manufactured from the lightweight yet durable ABS plastics and polymers. It weighs in at around 58 lbs which means this is the lightest hard-shell cover on the market. However light the product is that doesn't mean it's fragile. It can take a beating. Why? There are two reasons for that. First it's all about the applied material: ABS is widely used in the auto industry because of its amazing impact resistance and toughness. Second the cover has a strong X-effect understructure that made it possible to reduce the material mass without compromising the product's strength.
Having this cover installed you can rest assured that water won't reach those things you carry in the truck bed. The product features a full-perimeter weather-tight gasket seal that provides reliable protection when you're traveling in inclement weather conditions. And even if you live in a hot-as-hell state this cover will easily withstand the desert sun. Thanks to the materials and design it is capable of
Price: 2023.65
